Hello I currently have this build. I live outside the US, thats why some prices are a little bit more expensive.
CPU: Intel - Core i3-7100 3.9GHz Dual-Core Processor (Purchased For $128.61)
Memory: Crucial - 8GB (2 x 4GB) DDR4-2133 Memory (Purchased For $55.49)
Storage: Sandisk - SSD PLUS 120GB 2.5" Solid State Drive ($54.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (Purchased For $49.99)
Video Card: Gigabyte - GeForce GTX 1060 3GB 3GB Windforce OC Video Card (Purchased For $208.70)
Case: NZXT - S340 (White) ATX Mid Tower Case ($73.90)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($57.90)
Total: $629.58
Generated by PCPartPicker 2017-05-12 23:59 EDT-0400
And was having a little trouble deciding a MOBO. My options are:
ASrock Z270 Extreme 4 https://www.newegg.com/Product/Product.aspx?Item=N82E16813157743&cm_re=asrock_z270_extreme_4-_-13-157-743-_-Product
Gigabyte Ga-H270 Gaming 3 http://www.gigabyte.com/Motherboard/GA-Z270-Gaming-3-rev-10#kf
Gigabyte ga-Z270 Gaming 3 https://www.newegg.com/Product/Product.aspx?Item=N82E16813128973&cm_re=gigabyte_ga_h270-_-13-128-973-_-Product
Was wondering which one was better. I may evnetually like to upgrade to an i7 if that matters. Those MOBOs are the ones that the best technological store in my country currently has in stock. Was wondering if they were good options, i am leaning more to buying the ASrock but the H270 looks interesting.
Thanks in advance!
Total: $629.58
Thanks in advance!
