Help deciding two similar Asus laptops?
scythelord
Commendable
May 3, 2016
Hi guys I need help deciding which one of two similar Asus k501 laptops, so heres the deal:
K501UX-DM136T: i5-6200U, 8gb ram, 1tb hdd, gtx950m and $1,466.25nzd.
K501UB-DM052T: i7-6500U, 8gb ram, 128gb ssd +500gb hdd, gtx940m and $1,499.00nzd.
which one do you guys think its better and worth the money? thanks in advance.
Greetings scythelord,
http://gpuboss.com/gpus/GeForce-GTX-950M-vs-GeForce-940M
I would choose the k501ux soley because of the gpu. Check out the benchmarks in the link above. For gaming your i5 will be plenty in conjuction with your gtx 950. Remember when you get your unit, update your bios to the latest version 209. Then update your graphics driver via Nvidia control panel. Pop in a SSD of your choice and you are good to go! Good luck and happy shopping!
