Question Help! Display goes black whenever i touch cabinet
Jun 28, 2019
6
Help! Display goes black not monitor, whenever I touch or even tap with my finger on cabinet. Monitor light is on same for cpu it just goes black for 2-3 secs then comes back normal
Welcome to the forums my friend!
Do you get a static shock at all? Could be a short somewhere, make sure the PSU is properly connected and that the MB has been installed on all correct standoffs.
Does the CPU LED come on all the time or only during the black monitor?
No shock and CPU LED is on all the time. its a 6th month old pc this problem just started happening
I suspect it's more like a grounding or short somewhere with the case and internal components. My first step would be to look for metal touching metal somewhere.
Examples i've ran across:
  1. Upon installing a motherboard and I/O shield, one of the metal clips from the I/O shield inserted into my LAN port on the motherboard when installing.
  2. Not installing enough or case stand offs propperly.
I'd also consider swapping out the power supply to see if this resolves the issue.
