G
Guest
Guest
I've been trying to upgrade with a PCChips integrated motherboard using a 4.3 gig HD, AMD K-6 II 500 mghz processor, 64 meg PC 100 ram. The jumpers are all set properly (only jumper seems to the "clear cmoss" jumper).
The computer boots up just fine and goes through the bios searches for drives, etc. Then, just at the point where it would normally look for a boot record from the floppy start-up disk, the computer says, "verifying DMI pool data....." and then freezes up so that nothing else can be done. I can't get past this point in order to format the hard drive and install Windows 98 SE.
The strange thing is that I've gotten to this point gradually. I was able to fdisk the hard drive. But, now I can't to anything.
