[Help!!]Extreme Overclocking on AMDs FX-8350
flamehead269
341
I am wanting to fix up my fx-8350 with A VERY nice cooler so I can overclock that thing like crazy.. I prefer the water cooling over that huge noctua famed nh-d14 so what would be a good water cooler for the cpu only?
Also, i have a CONSAIR 750 Bronze Efficiency, and I want to make sure I have enough room left for an overclock of up to 5.2 Ghz, of course I don't plan on making that my default clock I just want it to be able to shoot up to that maximum. So I will list my current build down below.. I ask that someone get an accurate amount of wattage it already uses.. and how much I can overclock up to with my current PSU..
Also verify with me if my case will take the suggested cooler
Suggested Cooler:
COOLER:
http://microcenter.com/product/404944/Hydro_Series_H100i_Extreme_Performance_Liquid_CPU_Cooler
Current Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352023
Current Build:
GPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125439
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233299
COOLER:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
(Will be replaced)
BOARD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
HDD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
SSD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147192
Thanks Tom Community
swiftech h220 ftw best one to overclock an fx 8350 to 5ghz and maybe even beyond but without the low noise adapter
