Help finding watercooling store
Kcimor
79
Hi guys, i live in portugal, i want to buy white fittings, cant find them anywhere, do you guys know any store thag sells fittings?? As long as its an european store any is good, thank you.
Im trying to find something like this: http://www.aquatuning.pt/refrigeracao-a-agua/ligacoes/acessorios-farpados/1913mm/13985/19/13mm-compression-fitting-900-revolvable-g1/4-knurled-matte-black?c=11393
BUT in white.
That one a adaptor with compression fitting. I have only found in white the 90° adapter with g1/4 in both ends, not with a compression fitting one one end. If i buy just the adapter it would cost me double the amount to buy 1 adapter and one cmpression fitting for each hole, co.pared to having one fitting like the one i linked.
Well i guess ill give up on white fittings and maybe buy silver fittings. Thanks alot guys.
Faalin, found them on ebay uk after googling the part i found in your link, too bad it costs 2 times the price of matte black fittings XD so im probably not going to buy, will decide later.
Thanks everyone that replied!
thanks guys, i ended up buying white 8 barrow compression fittings on ebay, arriving this week + 7 monsoon 90° white adapter from aquatunning that arrived yesterday. makes for about 10eur each fitting combo, alot cheaper than 30€ for bitspower white angled fittins. Monsoon feels super high quality, this will be my 1st time custom watercooling, necer seen it in person, fittings look great. Ill make a full white build with purple coolant. thanks for the help anyway.
