HELP finishing 1st Build.
TheGloriousMR
18
I have tried several times now and i cannot get a internet connection i dont know if im missing a step or what. I downloaded the latest drivers from Gigabyte and i still cannot connect to the internet. I have a fresh install of windows on screen now and i am stuck. Any help on what i should install and in what order would be greatly appreciated
These are the specs: PCPartPicker part list: http://pcpartpicker.com/p/7M3M7P
Price breakdown by merchant: http://pcpartpicker.com/p/7M3M7P/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.98 @ NCIX US)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard ($104.98 @ OutletPC)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($47.99 @ Amazon)
Storage: Crucial BX100 250GB 2.5" Solid State Drive ($84.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.49 @ OutletPC)
Video Card: EVGA GeForce GTX 980 4GB FTW ACX 2.0 Video Card ($499.99 @ Newegg)
Case: Thermaltake Chaser A31 ATX Mid Tower Case ($65.99 @ SuperBiiz)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply ($44.99 @ Newegg)
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer ($19.89 @ OutletPC)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($89.95 @ OutletPC)
Did you install the LAN drivers? Or wireless drivers if youre using a wireless adapter
You should install chipset drivers first. 8.1 should install LAN and audio. You dont really need anything else
I wouldnt install programs like easytune or Gigabyte on/off. Theyre known to crash windows
And the VGA drivers if youre using onboard video
I feel so dumb i was looking under the wrong filter!! I was looking under applications. After hours of reading manuals and tiny letter on the mobo i suppose i was worn out. Thanks to anyone that replied. And thank you for the tips on the other Gigabyte software.
