Question Help for building my first pc
Aug 23, 2019
6
Hi guys, I am trying to build my first computer but I am not quite sure how do I select the parts. I wonder that is my budget (around 1200 -1700usd) is it good enough to build around with amd ryzen 3700x?
Also, is there any good mobo recommendation that can suggest (preferably ASUS mobo) like should I go with X570 or B450? I would like to have Asus as they are more reliable. I found in Newegg there are X570-E and X570F what are their difference and is Asus ROG X570 Crosshair VIII Hero (Wi-Fi) ATX better than them?
Also, on my gpu, should I go for 2070 super with my budget or it is still able to get 2080?
what other recommendation for the other remaining parts (power, tower ram etc)
I would appreciate with your help
Aug 23, 2019
6
Major usage? As detailed as possible pls.
B450 is good enough for normal usages.
hey vapour, I would use as playing game (PUBG, dota2, csgo etc) and sometime i would use AutoCAD for my work if need. I heard msi always have problem so is it good to purchase asus as they are more reliable?
motherboard is model dependent. I am using MSI for my 1st gen Ryzen, serves me well.
For you usage, Intel is actually better choice as AutoCAD/gaming all favor Intel.
gaming resolution? If 1080p, a cheaper gpu is good enough.
Aug 23, 2019
6
Shall I go for 9970k or which one will you suggest within the budget.
also what other parts will u suggest for the build
do you plan to overclock? If so, I will get below. You may change it to locked version and B3xx MB if you like.
PCPartPicker Part List
CPU: Intel Core i5-9600K 3.7 GHz 6-Core Processor ($219.00 @ Amazon)
CPU Cooler: Noctua NH-U12S 55 CFM CPU Cooler ($57.99 @ Amazon)
Motherboard: ASRock Z390 Extreme4 ATX LGA1151 Motherboard ($143.88 @ OutletPC)
Memory: Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3000 Memory ($59.99 @ Amazon)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($94.99 @ Amazon)
Storage: Seagate Barracuda Computer 2 TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Amazon)
Video Card: Asus GeForce RTX 2060 6 GB STRIX GAMING OC Video Card ($399.89 @ OutletPC)
Case: NZXT H500 ATX Mid Tower Case ($69.99 @ Best Buy)
Power Supply: Corsair TXM Gold 850 W 80+ Gold Certified Semi-modular ATX Power Supply ($99.99 @ Newegg)
Total: $1195.71
Generated by PCPartPicker 2019-08-23 14:53 EDT-0400
Upgrade GPU as you like.
Aug 23, 2019
6
Total: $1195.71
is 2060 better than 1070, also the Z390 is it good with B 450?
