Help for Gaming PC
Red9
31
I am building my first PC and I have been researching custom PCs for a while. I am nervous about building my own PC since I am terrified I will spend over a thousand dollars on a PC and it not work. I am making this a gaming PC, so I would also like to know if it is good for gaming. This means alot to me so thank you for reading this post. I will mainly be playing minecraft, Skyrim, and other games.
Case- http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160&cm_re=Cooler_master_haf_advanced-_-11-119-160-_-Product
Power Supply- http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095&cm_re=Seasonuc_620w_power_supply-_-17-151-095-_-Product
Motherboard- http://www.newegg.com/Product/Product.aspx?Item=N82E16813132116&cm_re=Asus_z97_pro-_-13-132-116-_-Product
CPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899&cm_re=intel_i5_4670k-_-19-116-899-_-Product
Memory(RAM)- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
Video Card- http://www.newegg.com/Product/Product.aspx?Item=N82E16814121770&cm_re=Asus_gtx_770-_-14-121-770-_-Product
HDD- http://www.newegg.com/Product/Product.aspx?Item=N82E16822236625&cm_re=Wd_black_1tb-_-22-236-625-_-Product
SSD- http://www.newegg.com/Product/Product.aspx?Item=N82E16820148820&cm_re=crucial-_-20-148-820-_-Product
Optical Drive- http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204&cm_re=Asus_drw-_-27-135-204-_-Product
Operating system- http://www.newegg.com/Product/Product.aspx?Item=N82E16832416806&cm_re=Windows_7-_-32-416-806-_-Product
Keyboard- razer blackwidow ultimate stealth edition
Mouse- Razer deathadder
Yes it's a good build and it will work.
However, I suggest windows 8 and the only reason why I even do recommend that OS is because it will yield better fps in games like battlefield 4 and such.
Red9
31
Red9
31
I don't really play FPS games like Battlefield 4, I am getting windows 7 because I am worried about compatibility with Skyrim and older games. I have read about those games on windows 8 and there were mixed answers, so I am going with windows 7 just to be safe. Unless you have proved otherwise.
That's fine, windows 7 is still a great OS that I still prefer.
you will not see a lot improvement in gaming thats for sure , but in certain situation ...somes apps need to use the memory
to doing a specific task and the transfert rate need to be faster between the ram and cpu
so for almost the same price you can have a faster transfert rate ram .
the only thing to take care is when you overclocking ...a faster ram can give you a stability issue , but its not certified
some people had issue when they overclocked an others never had issues so??
Red9
31
I don't really plan on overclocking, but i'll get the i5 4690k just incase I decide to overclock. I could always buy a stronger cpu cooler later on. But if I get 2400mhz RAM, I get stability issues?
