Help for New PC Build - WORTH or OVERKILL?
sekhworkshop
11
Mother Board - ASUS Z270G
Processior - 7gen i7 7700K
RAM - 16 GB Corsair ddr4
HDD - Seagate Barracuda 2TB
SSD - 250 GB(Samsung evo)
Graphic - Zotac 6 gb GTX 1060 amp edition ddr5
SMPS - corsair(750 w)
Hello everyone, I'm looking for a PC for streaming, gaming and editing.
What I like to do: play game on mid & high settings (60fps on 1080p)
fast enough to edit & render my videos (edit 4K video if its needed/possible)
Lag free Streaming & gaming (do I need a capture card)
And want to add custom cooling in future just for the looks 😀 So Please suggest me a case that is quite and best for my rig (One Side full windowed Case are looks great with custom water cooling and RGBs led. 😱)
Any help would be greatly appreciated :)
Maybe try something like this:
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor (₹17999.00 @ Amazon India)
Motherboard: Asus - ROG STRIX Z370-E GAMING ATX LGA1151 Motherboard (₹22500.00 @ Amazon India)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory (₹17900.00 @ Amazon India)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive (₹8599.00 @ Amazon India)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (₹3555.00 @ Amazon India)
Video Card: MSI - GeForce GTX 1060 6GB 6GB GAMING X Video Card (₹30600.00 @ Amazon India)...
Case: NZXT - Phantom 410 (Gunmetal/Black) ATX Mid Tower Case (₹6815.20 @ Amazon India)
Power Supply: Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply (₹6817.50 @ Amazon India)
Total: ₹114785.70
Generated by PCPartPicker 2017-11-01 21:55 IST+0530
Thank you so much for your help, but can you explain why you changed the processor to i5? Is this will do the job done or better to have i7 7700K (as I can afford this)
It's a newer generation CPU and has 6 cores as opposed to the 7700K's 4 cores.
Okey so relevantly it should be better than i7 7700k
Here in India it cost me 18000/- (i5 8gen)
And i7 7700K cost me 27000/- (in Rupees)
So what should I do? Should I go for i5 8th OR i7 7700k or should I go for i7 8500! I'm confuse with all this CPU, I really don't know much about this, does this PC is good for my workload OR it could be better by improved some area...
I would say it depends on what your biggest priorities are with this system. I personally would always go with the latest generation you can because you'll get better upgrade opportunities. Which you will by going with an 8600K or 8700K vs the current generation 7700K.
Look bro, I just want the perfect balance, no future! Just want to stay at present. I mean to say that I don't want spend any penny with just a thought of future or future proof, whatever you guys say it. And why should I care about future when I know exactly what I need right now and even in future, I just want edit my video and play Lot's of game in 1080p or 4K if I ever buy 4K monitor and do some live streaming gameplay that's all what I need and maybe I have add capture card like elgato or something for better live stream....just heard about this friend don't mind if I'm act like expert, when I'm not. I JUST DON'T WANT TO SPEND MORE MONEY, IF THAT IS NOT NEEDED RIGHT NOW(hope you understand my language)
It's not about how much money you spend. It's what I call "smart spending". Doesn't matter if you're spending $500 (₹32000), $1,000 (₹64500), $2000 (₹129065) or more. It's about spending it wisely. You want to get the most bang for your money possible. When you plan for a build, you don't have to plan for a build several years out. But longevity is always key when you select your parts. The 7700K is still relevant, but by buying the 8000 series, with the 2 extra cores you're guaranteed extra life out of your system vs if you compromise by going with the previous generation.
I just did some research for 8 generation processor and figure out that you are pretty right about my built. This better and also worth. But I also har.d about and ryzen, are they are more worth or not? I'm new here even I can't find how to reply to you properly (to g-unit1111
