jiopolicarpio1 :
mikeywhelan :
jiopolicarpio1 :
Guys, What should I do to fix this problem because whenever I play PUBG I get 30 to 10fps ingame. Is my PC bottleneck? If yes what should I do to fix bottleneck problem here's my specs:
CPU: AMD A6-7400K
RAM: 8GB (6.96Usable) Dual-Channel DDR3
Motherboard: MSI A68HM-E33 V2
Graphics: NVIDIA GeForce GTX 1050 Ti 4gb GDDR5
Storage: 500gb
CPU is holding you back pretty bad. This game is quite horribly optimized though, give it a few stages of development and the performance might improve. If you really really want to play the game, look into a new CPU.
Okay, but what type of CPU should I buy that is compatible with my GPU and Motherboard?
On your mobo you don't have a good choice right now. Have to upgrade mobo/ram. Another thing is AMD APU has a average cpu performance and way better gpu performance. Now you are using a discrete nvidia gpu and you are not actually taking advantage of the apu. It can be done by adding a compatible Radeon card and crossfire it with your APU.
Since your cpus compute performance is way low, you can not get a better cpu on this mobo becs there is nothing there in amd apu line which is significantly better. You have to switch it either to ryzen which has best upgrade path right now or intel 7th or 8th gen cpus.
