Hi guys! I'm new here. I want advice on upgrading my gpu. So here's the one i'm currently using.
http://www.msi-computer.co.jp/VGA/R6950_Twin_Frozr_III_PE_OC/#img/R6950_TF_III_PE_OC_IO.jpg
I bought my gaming rig (assembled it) in Japan, so just google translate the link if it's in Japanese, because i can't find other sites with the same info.
My gpu still performs well but i can't play new high graphic games (2013 onwards) because they stopped making drivers for this gpu since 2013 and most new games require the later driver versions. Other than that it still works fine considering i've had it for 5 years now.
My priority for upgrading is getting a card that will still be usable for the games in the next 5 years (with available drivers unlike my current gpu), at higher resolution (UHD if possible, or a bit lesser), something that won't overheat (i think i won't need OC, i never used OC) and performs well. My budget is $400 and below or slightly higher.
Here's my motherboard btw: https://www.asus.com/ROG-Republic-Of-Gamers/MAXIMUS_IV_EXTREME/
And currently i have 750w psu (i think but it might be 850w, i forgot).
And i'm on 2nd gen i7 processor.
I hope you guys can help me. Thanks!
