HELP!! Hard bricked my LG and need help on accessing its memory and its testpoint!
ProudlyTM
24
OK, so the model of my phone is LG L Fino (D290N) and I really need to know how to short its memory chip testpoint to be able to copy stock aboot.img with dd command on Ubuntu (And no, I do not have access to QHSUSB_bulk mode. I wouldn't have disassembled it if I had access..).
I took some pictures:
Front side of the board + front camera unplugged: http://imgur.com/aPgzaGU
Back side of it + front camera unplugged: http://imgur.com/8dxBces
Digitizer and screen part: http://imgur.com/k4kppmk
P.S.: I think I might have found the memory chip: http://i.imgur.com/PA6BLuC.jpg
(I redrew it over the original picture because it's too dark and almost nothing can be seen in the bottom part of the picture)
You would more than likely be better off asking something like this over at XDADevelopers where it is nothing but mobile/tablet devices. What you are doing is some pretty deep debugging that most uses do not do so finding help might be a bit of an issue.
Already asked in XDA, nobody out of the 133 people that viewed my post answered anything.. Whatever I will just exchange the phone for a new one, it's still under warranty.
Well, I tried to install TWRP, but I messed up the phone's partitions.. That's how it all happened.
Ohhh...well you SHOULD still be able to access FASTBOOT, find a .img of the original boot or a different version of TWRP and then flash it though Fastboot. You're bootloader is unlocked correct?
Also if the phone had its bootloader locked and you unlocked it, and if they find you flashed it with TWRP that voids your warranty ya know.
