Help help help
Your CPU is roughly on par with the MINIMUM required for that game. Your graphics card and amount of system RAM (based on your other thread) are far below the minimum required.
There is no way your system is going to run this game well.
These two links will tell you approximately what level your CPU and GPU are compared to other CPUs and GPUs.
CPU: https://www.tomshardware.com/reviews/cpu-hierarchy,4312.html
GPU: https://www.tomshardware.com/reviews/gpu-hierarchy,4388.html
Also, please do not start a separate thread for each individual game you want to play. Ask it all in one thread.
