Hi,
I am a total noob in overclocking. I want to overclock my i7-6800k to around 4Ghz. I've read and watched youtube but I am still uncertain. Can you guys give me a step by step things to do? I kept reading that I need to increase the multiplier then test then increase again until i get an error, then i increase the voltage until the error goes away then increase again the multiplier, etc.
Anyway here is my computer setup:
i7-6800k
Noctua NH-D15s (single fan only)
Corsair 780T case (stock fans)
Asus X99 Deluxe U3.1 (version 1 only - BIOS updated to latest)
Gskill ripjaws 32GB RAM (4x8GB)
Geforce GTX 760 (soon to be GTX1070 or 1080)
Corsair AX860i power supply
Samsung 950 Pro M.2 SSD - 512GB
Samsung 850 Pro SSD - 512GB
WD Black 4TB HDD
WD RE 6TB HDD
Windows 10 Pro 64bit
My usage = Photoshop / Lightroom / Light premiere (to study it this year) / Light after effects (to study it next year) / Light gaming (Starcraft 2 - once or 2x a week)
Questions:
1) I've seen others set the multiplier to 4.2x then voltage to 1.22v (to give them 4.2Ghz) but I only want 4Ghz (for mild overclock) so maybe I should set my voltage to 1.1v or 1.2v first?
2) Some said to use stock setting for Ram while others say to set it to XMP before overclocking. Which is right?
3) What program should I use to test? Some say to avoid prime as it will destroy your computer. Should I use Aida64, XTU, Prime, etc? (I prefer the free version but I can pay if it is really that much better). How long do I need to run it?
A step-by-step guide would be really good.
Thanks.
i7-6800k
WD Black 4TB HDD
WD RE 6TB HDD
Questions:
Thanks.
