G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
I must have wasted about 5 or so sheets of audiocassette labels trying to get
the design to fall into the right place. The first time I tried, it came out
way too high on the page, so I calibrated the printer by wasting a label sheet
(you have to fold it both ways to find the center). Then I used a new label
sheet and printed again, it's way too low on the page. I reset the calibration
and it's in a new (third) position (on the new sheet). Using another program
(Paint Shop Pro) confirms that by printing a horizontal black line in the same
place each time on the same sheet, it cannot print on the same vertical place
twice!
My old Canon BJC-8200 could print on the labels fine until I destroyed the
printhead by scraping it with a screwdriver in a futile attempt to unclog it (I
already tried the ammonia trick and then gave up).
The only workaround is to print out the cassette label design onto regular
paper, then cut out one cassette label and tape it in place over the design by
holding it over a bright light.
It seems to me that the printer cannot sense where the top of the paper is, but
only with labels. And they are not clear, and I tried cutting off a little from
the top too.
twice!
the top too.
