I was having trouble with hard reboots when playing Witcher 3. Narrowed it down to the power supply which was a Corsair HX750 which is only 3 years old. I order an evga 850 P2 from amazon almost a month ago. I installed it 4 days ago and it was DOA. Call amazon, get another one sent as a replacement. It arrives yesterday and I install it. I connect the windows SSD drive and start up and it boots up directly into windows, I run the Witcher 3 and it finally runs, Yay!
I shut it down to reconnect the rest of the hard drives. The SATA cables that came with the new power supply as too short and have only 3 connectors per cable so I used the cable that I previously used to connect 4 hard drives together.
The Blu-ray drive and windows SSD were on a separate cable. I start up the computer and get a smell of electrical burning/ozone. After temporarily freaking out, I am at a windows login. Hmm, maybe I reconnect the drives in a different order and the boot order is messed up. Go into the BIOS and the only drives visible are the SSD and Bluray. All drives that were on the old cable that I previously used are gone. I'm now getting 3.33V, 5V and 12V on the correct wires from the SATA plug that the failed drives are on.
The bluray and ssd are on different controllers so the controllers didn't get zapped. I moved the good cable to linux drive and 4TB backup drive and nothing.
I pulled the 4TB backup drive out and put it into an external case. It doesn't spin up.
At this point, does anyone have any suggestions? I'm open to a data recovery service depending on the price. I know it's expensive. Is something like this an easier (cheaper) recovery than other failure types since it's just the electronics?
It's not a total loss. I was backing up my financial docs, and document scanner folder to spideroak but 120G of music, 500GB of movies served on plexmediaserver. The past 15 years of photos of my life. Ugh.
Let this be a lesson. A backup isn't a backup unless it's external.
I guess I can now play Witcher. So I've got that going for me.
But seriously, does anyone have any suggestion or even a recovery option for one drive? Thanks.
Motherboard is an ASRock Z77.
Windows SSD
1TB Western Digital Ubuntu install that was daily driver
1TB Western Digital backup drive
4TB Western Digital backup drive that was mirrored via bash/rsync
4 HGST (ordered on May 21st!) EXT4 backup drive that mirrored the 4TB WD drive via bash/rsync
