Help Identifying Power SW HDD LED SW pins (Dell 660s Pinevalley)
MishalM
7
So I was upgrading My Dell 660s With a New PSU, GPU and a Case. It was going well until I came to this issue, I have no idea how to place the Power, HDD Led switch modules to my Mobo, please help!
And yeah, My mobo is a Dell Pinevalley DIB75R and this is how the pins look like:
• x (X=No Pin)
Plug it like this:
[HDD+]---> • • <---[PWR LED+]
[HDD-]----> • • <---[PWR LED-]
[RESET]--> • • <---[PWR SW]
(None)---> • x (X=No Pin)
(None)---> • •
Worked like a charm (Didnt plug in the Reset Switch because The Original Dell Power Connector did not have a Reset Switch, Just scared that it might wreck my motherboard.)
Thanks for your help, I Owe You!
How did you get this to work? I have the exact same pc. A dell inspiron 660s and I put it into a new case and upgraded the psu and put in a gpu and upgraded the cpu. I can plug everything in except for these little plugs(the power switch etc.). How did you get it to work because I followed the diagram someone sent you and it didnt work.
