HELP in building the Ultimate PC
The Connect 3D is a much poorer quality board then the Sapphire <---with 2 P's
<font color=red>120% ATi Fanboy!</font color=red>
<font color=red>3DMark 03 = 4,101</font color=red>
<A HREF="http://service.futuremark.com/compare?2k3=775464" target="_new">http://service.futuremark.com/compare?2k3=775464</A>
Nope i was wrong about the final question because i have another one, and that is is there any difference in motherboards between the IC7 and the IC7-G except the LAN because theres no need in buying the IC7G if it just has LAN...
thx again
<b>---Ashmore---</b>
<font color=blue><i>It's always funny until someone gets hurt.........and then it's just hillarious!</i></font color=blue>
IC7-G version has more Serial ATA connectors than IC7. But, I doubt you'd ever need them. If you got a Serial ATA hard drive down the road you could still use it with IC7. If you don't need the LAN, just get the IC7.
yup me again, i have 2 more questions...
First question: Where is the best place to buy a pre-modded PC case, i dont wanna spend over £100 for a case though, as you probably notice i have got down a case already as a guide.
Second question: i need a PSU again because a computer retailer told me that its is absolutely pointless in buying that 460 watt Enermax? so how much watt do i need?
thx again
Dan’s Ultimate PC component list
CPU: P4 3.0 GHz 512Kb S478 Box 800FSB £350.00 URL
Motherboard: Abit IC7 S478 Intel 875P ATX A L £135.40 (PC Parts)
PSU: ??? £
RAM: Corsair Platinum XMS3500 434MHz 512MB DDR £113.96 URL
Hard Drive: WD Caviar 120.0GB UDMA100 Special Edition £104.50 URL
PC Case: Blue LED Front and Side Panel Opening Flap Reveals 2 USB’s £60 (PC Parts)
Monitor: Iiyama Vision Master Pro 454 19" CRT 1920x1440 85 Hz 0.24 mm £277.29 URL
Graphics Card: Sapphire Radeon 9800 Pro 128MB DDR AGP RP DVI VO £358.01 URL
Sound Card: SoundBlaster Audigy 2 Platinum EX PCI £167.00 URL
DVD-Rom: Lite-ON 16xDVD 48xCD £27.00 URL
CD Re-Writer: Lite-ON Internal IDE CD/RW 52x24x52x £37.00 URL
Speakers: (Will be using optical out/SPDIF)
Mouse/Keyboard: (Already got PS/2 Microsoft Internet Keyboard and Mouse)
Total =
350.00
135.40
113.96
104.50
60.00
277.29
358.01
167.00
27.00
37.00
£1630.16
so would there be any difference if i bought a 300/350 watt PSU then a 400 watt, please explain
Yes. For the listed components, if you go with a 300/350W power supply, you run the risk of the system being underpowered. Which will cause stability problems.
hey guys
Im gonna be ordering the beast tomorrow, the price for it built without the monitor will be £1479 complete :)
Just in case you were wondering heres the FULL specs of it:
PC Case: Case Blue LED’s front USB supplied with 400 Watt PSU £54.00 (PC Parts)
Graphics Card: Sapphire Radeon 9800 Pro 128MB DDR AGP (RETAIL) DVI £358.01
Sound Card: SoundBlaster Audigy 2 Platinum EX PCI (RETAIL) £167.00
DVD-Rom: Lite-ON 16 x DVD 48 x CD (RETAIL) £27.00
CD Re-Writer: Lite-ON Internal IDE CD/RW (RETAIL) 52x24x52x £37.00
Total =
350.00
135.40
113.96
104.50
54.00
277.29
358.01
167.00
27.00
37.00
£1346.87
£1479 (built at PC Parts)
