Help, in Choosing between two graphics cards, Please. and a question :
angeknight
Hello,
I was originally going to run crossfire with
SAPPHIRE 100245HDMI Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102824
However it was suggested that one
XFX HD-577A-ZNFC Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150447
would be better. Any suggestions i do not wish to spend more than 200 on the card/cards.
Also the two boards im looking at say the fallowing the gigabyte says PCI Express 2.0 x16 (2) ;however, the Asus says PCI Express 2.0 x16 - 2 (one x16 or dual x8 link). Does this mean that on the gigabyte board crossfire could run at 16x while on the asus it can only run at 8x?
GIGABYTE GA-MA790GPT-UD3H AM3 AMD 790GX HDMI ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128398
ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402
thank you any help would be appreciated, and thank you for reading the post as well as your time. :bounce:
Well, two 4850's in crossfire will only be slightly better than the 5770. (Just a couple of frames)
My suggestions is to buy a 5750 now, then crossfire with a second one after the prices drop (Should be around the time that Nvidia releases their DX11 gen.)....or just get the 5770. I tend to overthink my purchases. :)
@the second question: Yes, that is exactly what it means.
