Help in Customized Water Cooling Loop
skyflex
19
Hi i have a Corsair Hydro Series H100 as a CPU Cooler and im thinking of switching to Customized Water Cooling Loop. It's my first time building a Water Cooling Loop. Can someone please help me out, in regards to the needed parts and where to get them best quality and best price please. Your help is much appreciated.
- Mother Board: Rampage 4 Extreme
- RAM: G.Skill Ripjaws Z Series
- GPU: EVGA 015-P3-1580-AR GeForce GTX 580 (Fermi)
- Case: Cooler Master HAF X RC-942KKN1
manofchalk
Glorious
First place to start is the watercooling sticky, it will teach you all the background info needed to start watercooling. Chances are it will answer most of your questions.
http://www.tomshardware.com/forum/277130-29-read-first-watercooling-sticky
I notice that your using a HAF-X, have a look at my build log (in my sig), I also use the HAF-X and seeing how other have done it in your case and the issues they'v run into will make it a much easier for you.
For instance, motherboard clearance is an issues in this case. Dont put thick rads at the top.
Similar threads
