Question Help in pc case fan size
Probably 92mm which is just one standard.
Also measure the depth. Possibly, it is 25mm, but from the looks of it, I think 38mm is more likely.
Also, look at the fan connector. It looks like a 3 pin analog connector, but it could possibly be a 4 pin pwm connector.
Regardless, here is one site with a large variety of fans available:
https://www.frozencpu.com/cat/l1/g36/Fans.html?mv_pc=5466572
it was 38mm depth and 4 pin connector, does depth matters?
Depth may or may not matter.
A 25mm depth will not move as much air as 38mm, other things being equal.
If max airflow is important, stick with 38mm.
Possibly, the mounting location may have some restrictions, but using a slimmer 25mm unit is likely to do fine if you want that.
What is this fan used for?
If it is a case fan, then any 92mm fan is likely to work.
If it is a cooler fan that needs to be installed in some sort of a frame, then better to match it exactly.
Reactions: JustRedy
I bought a pc fan with small depth than my 38mm old pc fan has,
