Help in picking a MOBO!
jejemon1012
157
The motherboard is the only left we are having problem to complete our new PC build. We are not into overclocking and we don't want an expensive motherboard because we're not into overclocking and stuffs. Our budget for the motherboard is 100$ less I guess. And I found this 2 motherboard but the other one doesn't have a bluetooth and a wifi built in which is nifty if it's built in but it's small, and the other one has 4 ram slots and two pcie for the gpu. Here is the link of the two motherboards that have caught my attention.
1. https://www.msi.com/Motherboard/B150M-NIGHT-ELF.html#hero-overview
2. http://www.gigabyte.ph/products/product-page.aspx?pid=5639#ov
If you guys can recommend me a better one then that would be great!
Question, do you NEED WiFi and Bluetooth? Also, are you planning on doing SLI or Crossfire? I wouldn't think so if you are on a budget. Also two RAM slots are enough, because again, you are on a budget. I would go with the Gigabyte choice, if it is cheaper.
If the RAM and PCI slots really concern you, the MSI could work, and down the line, you could get USB dongles for WiFi and Bluetooth.
