Help installing memory.
Green2CPU
6
I am looking for some help installing memory on my AMD Athlon 64 3700+ Processor . I believe the Mobo is MSI K8NGM2. I currently have 1 512MB DDR SDRAM PC3200 Hynix HYMD564646CP8JD43, and I am installing 512MB DDR SDRAM PC3200 Kingston KVR400X64C3A/512. Since I'm unclear if these two sticks would work well in dual channel, I am looking to install them to work in single channel.
It's normally not something you can control manually. The MB tries to run in dual-channel mode, and if it can't, it runs in single-channel mode automatically. Just be sure to install one DIMM in each channel (not both in one channel and none in the other channel).
