[SOLVED] Help jagged edge anti aliasing in some games
Nov 3, 2020
36
6
45
So I have this graphics anti-aliasing problem it is in some of my games but it is most noticeable in GTA five for example the map like the road
lines on the map are very jagged looking the model of my character is very jagged looking the edges are very jagged I am using a RX 570 4 GB. And a i5 3470 with 8 go of ram
Which resolution are you using?
Your GPU can easily handle GTA V on 4k resolution and doing so will remove all the jagged lines.
And, put MSAA to off or to 2x.
