[SOLVED] Help locating cmos battery for msi z390i mobo
Oct 23, 2019
So the symptoms are that the pc will not post sometimes on a single press of the power button. When it does post, the time is not synced. It does seem like the cmos battery might be dying, but i cannot locate the battery. Appreciate of you can help me out!
Hi, i cannot locate the battery on the mobo, i’ve read through the manual and also never seen it during the build process
I see what you mean. That is really weird. And I've never seen a board with a M.2 slot on the back, either. Rough if you ever want to change it.
But the battery might be part of the board's componentry... non-replaceable. See if leaving the board powered up for an hour or so charges it.
