Question Help Locating Installed Drivers in Device Manager
accesscpu_
224
I'm attempting to ensure my chipset drivers are the most up-to-date, and my motherboard's installer is giving me info that suggest it's attempting to install older versions of what I already have (I presume my current versions were delivered via Windows Update). I need to check the installer's versions against the currently installed ones I have in Windows 11.
How can I find these installed drivers in Device Manager, to verify the version I'm currently at? I'm not seeing them, but may not know where to look exactly...
  • AMD Processor Power Management Support
  • AMD GPIO Driver
  • AMD GPIO Driver (for Promontory)
  • AMD PCI Device Driver
So I was able to research further and found out the model of my motherboard is the PRIME B550M-K (which is not always easy to tell in the ROG pre-built systems).
Here's my issue. I'm confused on which drivers are going to give me the latest chipset drivers.
I can either use these (which are the ones I started with) from the ROG official website
OR
These I found from the motherboard's website (but the installer prompts that I may be downgrading the version).
Any suggestions?
