You can't install Windows 7 without a valid license key and disk. If you bought a copy, you should have both, if you have an OEM system from Dell, HP, etc..., they can send you a system restore disk. Otherwise you will need to download a Windows 7 ISO file which are tough to find now since Microsoft removed their official ones, use an ISO to USB utility (MACs should have that but I have never used one on that platform), and install using that and the code that should be on the computer.
