Hi every One .. i want to buy 5850 & i use GA P31 DS3L {that already has 1 PCIE Slot } & i am using PORSCHE Case ....
now here is the problem ... MOBO can run it fine ... but i dont know if 5850 will fit in my case or not ... i am using 9600 now . IF i had problem with space ...which one i should upgarde ... Motherboard or Case ? if it is a CASE so please suggest me a good case with enough space for this CARD .. { Not so Expensive one please }THANKS
