Solution COLGeek Mar 13, 2018 This is the CPU that comes stock with the laptop: https://ark.intel.com/products/27234/Intel-Core-Duo-Processor-T2300E-2M-Cache-1_66-GHz-667-MHz-FSB Note the socket type, you MAY be able to install other CPUs that use that same socket. A list of CPUs that will work in that socket can be found here: https://en.wikipedia.org/wiki/Socket_M Keep in mind that the Vaio's BIOS may not work with all of these.
COLGeek Cybernaut Moderator Apr 6, 2009 54,233 3,431 179,340 Mar 13, 2018 Solution #2 This is the CPU that comes stock with the laptop: https://ark.intel.com/products/27234/Intel-Core-Duo-Processor-T2300E-2M-Cache-1_66-GHz-667-MHz-FSB Note the socket type, you MAY be able to install other CPUs that use that same socket. A list of CPUs that will work in that socket can be found here: https://en.wikipedia.org/wiki/Socket_M Keep in mind that the Vaio's BIOS may not work with all of these. Upvote 0 Downvote Solution
