Help me battlefield 3
meximexi
17
well i wanna know if my PC is good enough to play battlefield 3, i want to made an idea of how it will be, right :B this is my PC
Intel core i5 2300 2.8ghz
-6 ram
-amd asus hd 6570 1GB ddr3 directx11
-sound realtek
Windows 7 64bits
thanks to all :B
Actually ASUS produce AMD based boards too
http://uk.asus.com/Graphics_Cards/AMD_Series/EAH6570DI1GD3LP/
meximexi I think your going to struggle a bit with that graphics card the rest of your system is more than enough but I think you will need to turn of the AA settings even if you game at lower resolutions and likely play at low with some medium settings. Try to upgrade that graphics card when you can its really letting your system down
