Ok so how do I start?
I bought a pc on 2014 but there was some problem i sent it to the repair on 2017/2018 but just yesterday i realized the technician swapped my whole parts except the fan (long story, dont ask why or how) so my pc now has gone from this spec:
More info:
- intel i3 4130
- Asrock motherboard
- Gtx 750
- 4gb ram corsair
- Seagate 1tb
- motherboard: asustek p8h61-m lx r2.0
- cpu: intel pentium g2010 @ 2.8 ghz, 2800 Mhz, 2 core, 2 logical pro... (got cut off from system information)
- Gpu: onboard (intel hd graphics)
- Power supply: hexa+ 500w
- Hdd: TOSHIBA DT01ACA100 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5"
- Ram: 4 gb, no idea about the details
- Casing: venomrx god of wind
- Just add the GPU. If this is the option, what GPU should i buy to match 1060? Or at least very close?
- Change the CPU and GPU. If this is the option. What CPU and GPU combo I should buy to be able to use 1060?
- Change the motherboard, CPU and GPU. what should I buy to be able to use 1060?
More info:
- im good with medium setting for 2018-2019 games but i expect older and much older games to run on high to ultra.
- I prioritize stable 30fps but dont really care for 60fps.
- Budget is usd500 for motherboard, cpu, AND gpu, if its not possible im fine with lower specs...
- Sub-1080p monitor but maybe will replace with 1080p in the future...
- My monitor has vga cable
- Im a casual gamer i played some big name RPG like witcher 3 but i dont care about gaming tidbits nor do i play everyday/week
- I really dont want too much power id probably wont use
