Help me choose a graphic card; I'm stupid!
Zezmezzie
11
Hi! I wouldn't say I'm a beginner, by a long shot, I understand most every aspect of the interworkings of a modern Turing machine though the one thing that has always vexed me is graphics cards. So, I need your help. This is the PC I will likely be buying as a base to upgrade from:
http://www.amazon.com/dp/B0141HCZZ0/ref=gbps_tit_s-3_3022_56a7e2ee?smid=AT5ZWRAJ36F48&pf_rd_p=2292853022&pf_rd_s=slot-3&pf_rd_t=701&pf_rd_i=gb_all&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0BXGGMVZHC0EC8DW61H0
What kind of graphics card would you recommend I upgrade this with, seeing it ships with integrated graphics(gross). Also, someone in the review section warned that I should purchase a "half-height card." He didn't say why, and quite frankly he could be full of it, but seeing as I have the knowledge of an infant in this subject, I figured it would be worth mentioning.
Thank you so much for your feedback; unless you're wrong, then screw you.
Cool, thank you.
Do you have any suggestions? I can put the thing together if I have all the pieces; it's just that there are so many specifics when it comes to components, it's really just over my head.
well heres my pc that i recently built,http://pcpartpicker.com/user/kyrim/saved/TCwQzy and if you have no experience building then you can easily watch tutorials, or ill even try to help you out, and if you dont have a DVD drive you can buy one for around 17$
and also, that build dont have a Harddrive, i forgot, i just used one from my old computer it worked just fine, but if you need a harddrive and a DVD drive, then ill add on in on the list and resend it to you.
