Hi,
I am building a PC soon and can either buy a hd 7970 but i will have to spend £40-50 less on a case or buy a hd 7950 and keep the £80 nzxt case. (another option may be the r9-280x)
Please help choose between these three cards:
Card 1: http://www.scan.co.uk/products/3gb-asus-radeon-hd-7970-matrix-platinum-6600mhz-gddr5-28nm-gpu-1050mhz-2048cores-4xdp-2xdl-dvi-plusf
Card 2: http://www.scan.co.uk/products/3gb-msi-radeon-hd-7970-twin-frozr-iii-oc-boost-edition-5500mhz-gddr5-28nm-gpu-1000mhz-2048-cores
Card 3: http://www.scan.co.uk/products/3gb-msi-radeon-hd-7950-twin-frozr-oc-be-28nm-5000mhz-gddr5-gpu-880mhz-1792-cores-dvi-hdmi-2x-mini-dp
Thank you,
Peran
Thank you,
Peran
