Hey guys, so my current build would be:
Ryzen 2200g
B450m motherboard
8gb Ballistix Sport Ram
1060 GPU
I also have 2 HDDs and 1 SSD
Given these specs, I plan on replacing my current Korean PSU since it's a hazard as most people would say here, so what would be the best for value and quality here in my choices? Thanks in advance for your help.
shopee.ph
-2850php
https://shopee.ph/Cooler-Master-Extreme-2-i.95657766.1673852224
-1500php
https://shopee.ph/CM-MPW-6001-ACABN1-PH-ELITE-V3-600W-i.20959443.1483894531
-2475php
https://shopee.ph/Coolermaster-MWE-550W-80-Bronze-Power-Supply-i.77398075.2075891365
-3050php
https://shopee.ph/CoolerMaster-MWE-500watts-i.68666145.2056042801
-2290php
shopee.ph
-1499php
shopee.ph
-2200php
https://shopee.ph/Silverstone-500W-80-Power-Supply-ST-50F-ES230-i.15914422.1198725551
-2650php
https://shopee.ph/SIlverStone-SST-ET650-B-Essential-Series-(Power-supply)-i.19056988.370980634
-3450php
shopee.ph
-2350php
https://shopee.ph/Deepcool-DE-500-V2-i.68666145.1482817006
-1595php
Ryzen 2200g
B450m motherboard
1060 GPU
Rave is the only available PSU here, sadly.
https://shopee.ph/Aerocool-Rave-PSU-80-600W-800W-Power-Supply-i.62858530.1369526293
shopee.ph
500w - 1980php
600w - 3140php
800w - 3835php
Aerocool Rave 500W 80+ Power Supply
Check this out at 10% off! ₱ 1,980.00 only. Download Shopee app now: http://goo.gl/qmhhw3
600w - 3140php
800w - 3835php
Cooler Master MasterWatt Lite 600W 80 Plus Power Supply
Check this out at 12% off! ₱ 2,850.00 only. Download Shopee app now: http://goo.gl/qmhhw3
-1500php
-2475php
-3050php
-2290php
https://shopee.ph/Thermaltake-PS-TPD-0700NHFAGU-1-Toughpower-GX1-RGB-600W-80PL-i.28528173.2098961560
-4290php
https://shopee.ph/BRANDNEW-Thermaltake-Smart-RGB-700-600-500watts-i.68666145.1351675675
-2390php for 500w
-2530php for 600w
-2980php for 700w
https://shopee.ph/Thermaltake-LitePower-650w-85-Effeciency-true-rated-PSU-i.15914422.735237046
-2650php
-4290php
-2390php for 500w
-2530php for 600w
-2980php for 700w
-2650php
https://shopee.ph/Corsair-VS650-650W-True-Rated-Power-Supply-i.25952313.316293994
-2832php
https://shopee.ph/Corsair-CS-CP-9020170-NA-VS450-PSU-80-White-Certi-i.28528173.2162072635
-1990php
https://www.lazada.com.ph/products/...o4l.searchlist.list.1.322b3cf3UOa3Wp&search=1
-2550php
https://www.lazada.com.ph/products/...4l.searchlist.list.47.9a7a3cf3RK80Gg&search=1
-3150php
NOTE: Sellers here may confuse the yellow with white rating... I'm not sure. The pics seem right but it makes me doubt...
-2832php
-1990php
-2550php
-3150php
RATED PSU 700watts 2nd hand (NOT USED) still sealed
Check this out for ₱ 1,499.00 on Shopee! Download the app now: http://goo.gl/qmhhw3
Strider essential Series 500W
Check this out for ₱ 2,200.00 on Shopee! Download the app now: http://goo.gl/qmhhw3
-2650php
-3450php
https://www.lazada.com.ph/products/...4l.searchlist.list.69.5eb66388jZfoXc&search=1
-2553php
shopee.ph
-1800php (seller verifies this is brand new without box)
https://shopee.ph/FSP-Raider-Power-Supply-650w-i.20295699.836773919
-2250php
https://shopee.ph/FSP-HYPER-K-500W-80PLUS-HP500S-POWER-SUPPLY-i.15914422.1944968283
-2200php
https://shopee.ph/Fsp-HEXA-APFC-Power-Supply-Power-Supply-500watts-i.14297410.1234138620
-2100php
https://shopee.ph/FSP-RAIDER-II-80-SILVER-Rated-w-Flat-Cables-Power-Supply-i.124819539.2140968328
-3200php for 550w
-2553php
Power Supply 700w Fsp Aurum s Gold
Check this out for ₱ 1,800.00 on Shopee! Download the app now: http://goo.gl/qmhhw3
-2250php
-2200php
-2100php
-3200php for 550w
Deepcool DP-BZ-DA600N-80 Plus Bronze 600W Power Supply Unit
Check this out for ₱ 2,350.00 on Shopee! Download the app now: http://goo.gl/qmhhw3
-1595php
https://www.lazada.com.ph/products/...4l.searchlist.list.11.70ee3c23igUWzV&search=1
-2495php
https://www.lazada.com.ph/products/...o4l.searchlist.list.9.70ee3c23igUWzV&search=1
-3095php
*I'm not sure about their wattage but basing off the description they are 500w and 600w respectively
-2495php
-3095php
