Help me choose a right psu...
rohit_rameswarapu
37
Hello, Friends i'm new to this forum i'm from india...
i'm stuck in choosing a psu for my new build can you help me in finding a best psu?
I have the following psu's in mind
Seasonic ss500es
Corsair cx500
Fsp Saga II 500w
so this are in my budget range so which one is the best?
If the comparison is between the Seasonic 500W S12II-500 Bronze (SS-500GB Active PFC) and the Seasonic SS-500ES (OEM) the Seasonic 500W S12II-500 Bronze has the higher quality and also has a 5 Year warranty. The OEM series usually only have a 3 Year warranty.
Efficiency-wise they are both 80 PLUS BRONZE certified.
The other difference is that the Seasonic 500W S12II-500 Bronze has one PCI Express 6-pin and one PCI Express 6/8-pin (a.k.a. 6+2 pin) power connectors and the Seasonic SS-500ES (OEM) has two PCI Express 6-pin power connectors.
The Seasonic SS-500ES (OEM) uses 105°C rated Japanese capacitors and is 80 PLUS BRONZE certified.
The Corsair Builder Series CX500 (CMPSU-500CX) made by CWT (Channel Well Technology) uses cheaper 85°C rated Taiwanese capacitors.
The FSP Saga II 500W uses cheaper 85°C rated Taiwanese capacitors.
It's a budget Corsair model made by CWT with cheap 105°C rated Taiwanese Samxon capacitor on the primary side and a mix of Japanese Chemi-Con and Taiwanese Teapo capacitors on the secondary side.
The Seasonic is still higher quality than the Corsair Gaming Series "GS" CMPSU-600G.
In the world of PSU's, always go for anything seasonic if its priced reasonably. Next up would be the corsair / antec / xfx and other higher models.
I'd go Seasonic then corsair and then FSP.
Cheaper taiwanese caps does not mean its crappy. Its just cheaper than high quality japanese caps.
The Seasonic SS-500ES (OEM) with its +12V current rating of 34 Amps will have no problem handling a single Radeon HD 5770 or Radeon HD 5850 graphics card system.
It will also handle two Radeon HD 5770 graphics cards in 2-way CrossFireX mode.
Okay fine can it even support the ati 68xx series?
I would recommend staying away from the Cooler Master GX Series RS-550-ACAA-E3 because that particular Seventeam design generates high electrical noise and ripple. Cooler Master is in the process of replacing the Seventeam made GX Series models with Enhance Electronics models in an attempt to improve the quality of that series.
The Corsair Enthusiast Series CMPSU-550VX has recently been discontinued but there is stock still in the distribution channel being cleared out. The quality is apparent in the use of 105°C Japanese Nippon Chemi-Con capacitors on both the primary and secondary circuits. You can read the following test review of this power supply here :
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=62
So even the corsair vx550 is to be an avoid or is it better than the seasonic?
It should be very similar to the Seasonic quality-wise.
Corsair's Enthusiast Series VX & TX is one of their better quality series. The two VX models have been discontinued.
What about the seasonic s12ii 620 bronze?
Anything seasonic is the thing to get IF its priced nicely. (such as a few more dollars than another model from corsair etc).
Corsair AX , TX , HX , VX is also very high quality units made by seasonic/cwt as oem.
For the Corsair VX models, when I said "The two VX models have been discontinued.", I meant to say that they were recently discontinued so there is still stock in the distribution channel that is being cleared out.
The Seasonic S12 II Bronze Series seems to be the retail versions of the SS-xxxES (OEM) series and SS-xxxET (OEM) series.
