Help me choose a workstation graphics card (meaning no gaming, just work)?
I'm building a amateur workstation where the primary use will be statistical computations (future GPU is possible), some photo editing using PhotoShop. No gaming.
Dual monitor, maybe triple.
This will be an Intel E5v4 2600 series platform.
Other factors are (at idle/low usage) noise, heat, power consumption.
The Intel E3v5 series uses the Intel HD Graphics P530, so I thought I would look for an equivalent or better from either nVidia, AMD, or other.
What is the recommended graphics card?
Thank you,
Jake
Thank you,
Jake
