[SOLVED] Help me choose B365 motherboard
Aug 21, 2019
49
As title says Idk what mobo to choose. I have Corsair Spec Delta case (Mid-tower ATX) and it supports RGB lightning only if Mobo Is ASUS, Gigabyte or MSI brand. My CPU is i7 9700 so I should buy B365 chipset. In my store there are only:
Gigabyte B365M DS3H 77$
Gigabyte B365M AORUS ELITE 98$
ASUS PRIME B365M-K 100$
ASUS PRIME B365M-A 103$
MSI B3650M Mortar 103$
ASUS PRIME B365 Prime and ROG STRIX same prices
ASUS MB SC B365M ROG STRIX B365-F 164$
The last one is ATX, while others are micro-ATX
I’m just a regular fortnite player, don’t do anything else
Idk what are the differences between them, only know that some of them have 4 slots for RAM, I have 2x8gb so don’t need 4 obviously. Want to save money but can afford some100$ one
What should I buy?
2060S
I7 9700
Hyperx Fury 2x8gb 2666MHz cl16
Corsair TX650M 650W Semi
Corsair Spec Delta (case)
Sure, you CAN buy a cheap board, but that's what you get. Most of the people we see come back here after a build are the ones that swapped out cheaper boards or power supplies after something with some quality was recommended so as long as you are aware that you're swapping quality for cost, then you won't be let down.
