[SOLVED] Help me choose between a 960 and a 970
Jul 30, 2021
13
Hello folks, I'm in the market for an overpriced secondhand gpu in this truly hellish market. I have a 720p monitor and I don't think I will upgrade it anytime soon so the gpu only needs to perform within that 720p resolution. The games I play are fairly light with the most demanding title being Apex Legends. I basically have two choices:
1. Go with a GTX 960 2gb for 150 usd​
2. Go with a GTX 970 4gb for 250 usd​
The 970 is obviously the more powerful card, not to mention the bigger vram but I don't know if I should pay that much for it and whether or not I can truly take advantage of its power, seeing as my monitor only runs at 720p.
Your psu is a bit small for a 970 but since your not pushing 1080p and an overclocked CPU it should be fine. I think for the money a 1050 ti 4gb runs around $170 +/- $20 and would be a better value over the 960 GTX 2gb. 🤷‍♂️
I'm seeing Apex legends gets 53.4 fps on high at 1080p here.
But THAT'S at 1080p.
So I'm thinking the 960 will do you fine at 720p.
Wow I didn't think a 960 can do that much!
