Question Help me choose between these two cases
Sep 12, 2020
13
Hi guys. Can you help me choose between Lian Li Lancool 215 and Phanteks Eclipse P300 Air. I will be doing air cooling and I will not be using any GPU. As I don't need a GPU. So, can you guys please help me choose one?
Both the cases are good, I'd probably go with the least expensive one given there aren't huge necessities.
However, have you considered smaller cases? This build won't generate a ton of heat, you don't have a GPU, and you're using a uATX motherboard. You don't really need something that large.
