Question Help me choose sa cooler!
Rhaemond
195
14
10,585
I agree, $4 more isn't bad. The GTE fan may also be better. Go with that.
That 240mm AIO is obviously going to outperform both Gammaxx coolers (and be 2-3x more expensive?) but I've never heard of that brand before. Pump failures are real, and an AIO doesn't perform very well if there's no water circulation.
If you want the looks of it I'd spend the $4
Noted!!!
I agree, $4 more isn't bad. Go with that.
Alright!
Yea pretty much it's a brand... But a very shady one I guess. They also sell cases, PSUs, etc. but dunno if they're actually good. I don't even know if there will be a big difference between the GTE and the cheap 240AIO
Noted!!!
Alright!
There probably will be a difference with the AIO but if something breaks or worse it leaks then you're left with a broken computer. I'd go with the air cooler as a Ryzen 3 even overclocked should be alright with those coolers.
Yea the safest bet would be from a trusted brand that can handle my Ryzen. Was just a bit paranoid I guess since the price is so cheap for the AIO and just wanted to take advantage of that
