help me chose a case
no help at all but thanks for the reply
Actually it is. ITs great advice. If you can afford it get the R5. If not, get the silverstone.
Sharkoon, thermaltake and whatever the f, you want me to recommend crap? sorry
The advice was good yeah, but the reply was crap dude.
Why are the listed cases bad? What makes the R5 better? Why is the Silverstone a good alternative to the R5?
I´m pretty sure previous threads have proven that replies like "just do that and it´s fine" don´t work.
That´s what I meant with "no help at all"
Im just condensing all my experience and summarizing it for you. After seeing too many cases to count i just recommend the fractal R5 as top case, and for budget build the silverstone.
Even with expensive NZXT cases over $200 au i'm having to push the back in so the installed cards can be screwed in. The fractal is 2nd to none. its well thought out and quiet. I dropped from a $400 lian li to this case.
The silverstone is the same thing with its counterparts regarding quality in the budget range. Of course it is a cheap case so dont expect R5 level
WHAT's your budget.??
i think you should go for a CM scout 2 advanced...a very awesome case with full cooling options upto 7 fans...also it has a good body made and a very sensible cable management system..so just go for it.
Thanks for the recommendation. I´m definitely going to take a look at the R5.
Will check it out.
Thanks
