I need advice, which is better build from these two - lets say that price is the same for both.
Is memory compatible in both builds?
I dont want to overclock just to plug and play without bios updating and playing in bios.
Pc will be used for games and modeling, sometimes rendering.
I am worried for ryzen 5 2600 temps, is it generally good when we consider temps with stock cooler?
BUILD1 - intel:
MOTHERBOARD: asrock-z370-pro4
CPU: i5 8400
GPU: gtx 1060 6gb
HARD DISK: WD blue 1 tb 7200 rpm (I dont need SSD for now)
PSU: Corsair CX650M
RAM: Kingston HX429C17FR/16 (16GB 1 stick)
BUILD2 - Ryzen
MOTHERBOARD: msi-b450-tomahawk
CPU: ryzen 5 2600
GPU: gtx 1060 6gb
PSU: Corsair CX650M
RAM: KINGSTON HYPERX FURY 16GB DDR4 2933MHZ / DIMM / CL17 / KIT 2X 8GB HX429C17FR2K2/16
BUILD1 - intel:
CPU: i5 8400
GPU: gtx 1060 6gb
PSU: Corsair CX650M
BUILD2 - Ryzen
CPU: ryzen 5 2600
GPU: gtx 1060 6gb
PSU: Corsair CX650M
