Question Help me find a 90-degree+ USB to Thunderbolt (Male to male) converter, please. (No cable/wire)
SeriousGaming101
330
Hello all,
I am looking for a DC power (Power from USB to Thunderbolt) 90-degree USB to Thunderbolt converter. That is MALE to MALE. (With NO cable/wires)
Something that looks like this: https://www.amazon.com/QIANRENON-Ch...ale+usb-a+to+usb-c+right+angl,aps,152&sr=8-39
The above item is USB to USBC but ironically, the USBC male for that item fits too loosely on my camera's back USBC female port (and keeps falling out) so I am going to try a male thunderbolt 3 or 4 converter instead.
You can try your luck with just looking up a Type A to Type C 90 degree and picking one of the plethora of options with a male Type A and female Type C then use a Type C male to male coupler.
Might work, might not, but would give you more options for a Type C connector that fits more snugly into your camera.
Thunderbolt is different technology btw. It may look the same because it uses a similar connector of Type C but under the hood it's a different kind of beast compared to just regular Type C USB.
or, perhaps a 90 degree USB Type A to Type A male to male/or female, then use a straight Type A to Type C adapter, either way getting 90 degrees but using two little adapters instead of one which is kind of jank but might be the only way to get what you need without being limited on options and finding something that fits more snug.
