Help me find a mini-ITX case for my ATX components
Jul 20, 2018
Hi all, I purchased the following ATX components ( See below) a long time ago and I now need to transfer them to a smaller case (Preferably a Mini-ITX if possible), since I do not have room for my full size rig now. I was looking into the Coolermaster 110, but based on the dimensions, my components will not fit. Any recommendations for the smallest size case that will fit my components would be much appreciated. Cheaper the better. Thanks!
Power Supply: EVGA E758-A1 3-Way SLI (x16/x16/x8) LGA 1366 Intel X58 ATX Intel Motherboard
http://
Mobo: CORSAIR HX Series CMPSU-1000HX 1000W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready 80
http://
GPU: SAPPHIRE Radeon HD 5830 DirectX 11 100297L 1GB 256-Bit GDDR5 PCI Express 2.1 x16
http://
Atx, mATX, mITX are form factors. As in sizes.
ATX = 12" x 9.6"
Matx = 9.6" x 9.6"
Mitx = 5.9" x 5.9"
An ATX form factor case will almost always fit mATX or mITX as the differences for the smaller boards are just in standoff placement. But there's absolutely NO way a ATX board will fit in a mITX case or mATX case.
You can throw a hotdog down a hallway, but good luck stuffing a cow into a shoebox.
What you will absolutely need to determine is exactly what dimensions you have available for the case space and then find an ATX mini/mid tower/cube that fits.
Karadjgne
Ambassador
ATX = 12" x 9.6"
Matx = 9.6" x 9.6"
Mitx = 5.9" x 5.9"
