S SebastianHELP Reputable Feb 7, 2016 136 0 4,690 Oct 22, 2016 #1 I'm looking for a monitor and my budget is $600 AUD, that sais it all . The monitor will be mainly used for gaming and the size should be minimum 27". Thank you!
Solution tothergnome Oct 22, 2016 It depends on what resolution you'll be playing on really. http://www.harveynorman.com.au/computers-tablets/computers/monitors/lg-31-5-mp58-full-hd-ips-monitor.html matches up with 1080P 60FPS gaming. If you're looking for 4K, http://www.harveynorman.com.au/computers-tablets/computers/monitors/samsung-28-series-5-ultra-hd-tn-monitor.html this should do the job.
tothergnome Respectable Mar 27, 2016 413 0 2,160 Oct 22, 2016 Solution #2 It depends on what resolution you'll be playing on really. http://www.harveynorman.com.au/computers-tablets/computers/monitors/lg-31-5-mp58-full-hd-ips-monitor.html matches up with 1080P 60FPS gaming. If you're looking for 4K, http://www.harveynorman.com.au/computers-tablets/computers/monitors/samsung-28-series-5-ultra-hd-tn-monitor.html this should do the job. Upvote 0 Downvote Solution
