Help me finish my gaming PC with 550$
djthiago1
38
I currently have a:
300W PSU
AM3 MOBO
Radeon 4670
Athlon II 265
4Gb DDR3 1333 RAM (PC3 10600 9-9-9-24)
Will probably need cooler after upgrade
I'm trying to save on RAM if possible buying similar RAM so i don't need to buy new say 1600mhz or more, unless if needed, that way i'll just add 4 more gigs instead of brand new 8gbs.
It's for gaming on my 1400x900 monitor.
My cart on newegg currently has these:
MOBO http://www.newegg.com/Product/Product.aspx?Item=N82E16813130637
PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817182068
RAM http://www.newegg.com/Product/Product.aspx?Item=N82E16820231394
Processor http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
GPU http://www.newegg.com/Product/Product.aspx?Item=N82E16814202077
Cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835103064
Thoughts on it?
D
I see no problem at all with your new build. I was not going to post because I hate having to click links to see what parts are when you could have just copied/pasted the part name with the link. 😉
Power supply is excellent.
CPU, motherboard, RAM and graphics cards are all fine for a budget gaming build.
At 1440 x 900 it should perform very solidly allowing you to max most games.
Just for future reference you are posting these threads in the Forum Feedback section of the forums. This section is usually reserved for, as it says, feedback about the forums. You will get many more replies from more knowledgeable users if you post in the correct forum subsections your questions pertain to.
This thread for instance belongs in Systems-Homebuilt. I have moved the threads for you 😉
OMG dude, you have no clue of what i want do you?
I want OPINIONS on the items on my CART. Not on what i have. I want to know if it's good or not.
Are you kidding me? I know there are better ones! Did you not read the 550$ part? Did you not see the extra 4Gb RAM on my cart making it 8GBS TOTAL!?
It's like someone asking your opinion on buying a VW Beetle or a Jetta, and you go like: "Dude, why don't you buy a Porsche?"
Sweet Jesus, thank you for answering what i wanted to know.
Next time post the part name in the thread with the links. Quite a few of us older members just see a link and go on to the next thread. Too time consuming to click 100 links a day to help 10 people when reading the part name in the thread takes 2 seconds.
But glad I could help! :)
