Hello Folks!
I have a modest setup of Ryzen 3 3300X and a Gigabyte Gtx 1660 super oc 6gb dual fan with B450M A PRO MAX and 8gb of Adata xpg 3000mhz Ram. 1 x 250 SSD and 1 x 500gb Hard Drive.
Anyways, this system is a pre-built by a company in my country and the power supply is manufactured by them which am sure isn't reliable or may cause a problem in the near future. The brand is Aures 500W 75% real efficiency. So, I want to change the power supply and since in my country hardware is so expensive am on a budget and also with few options.
1. Cooler Master MWE 650 Watt Bronze = 115$ (Expensive I know)
2. GOLDEN FIELD 600W +80 GOLD FULL MODULAR = 95$
My other options are:
Thermaltake Smart Rgb 500/600/700W (around 80$)
Thermaltake Litepower 550/650W (around 74$)
RAIDMAX VORTEX 600W RX -600AE-V (80$)
XFX 500W 80 Plus Bronze (80$)
Other options include the same cooler master but gold full modular but more expensive and over my budget.
Any suggestions? Also am using an APC UPS just for when the electricitygoes off cause am afraid that the psu will fail and damage other components.
