Help me OC i5 3570k
kvisteen
50
Pictures from BIOS: https://imgur.com/a/kx7Ba
Hey,
I have a problem with overclocking my CPU, I can't put the multiplier on more than 38 (default is x34) I know that I've had it on 40 in the past (4 GHz) with the same motherboard but I'm so confused since I can't choose anything higher nomatter what I do.
Also why I'm trying to do this is to boost the RAM memory speed aswell, I have 2400 Mhz ones that only run at 1600 atm.
Help needed!
/G
Tried to change to OC GENIE II but nothing could be changed, got told once I restarted that I shouldn't manually change values once it's turned on. It automatically controls the computer it says.
Thanks for trying to help but that didn't work sadly
