Question help me please for record
Aug 14, 2019
4
I updated my version of Windows to 1903 version and after the update I use the record program for Windows ( game bar ) does not work and write to me ( sorry this pc doesn't meet the hardware requirements for recording clips )
and i was record before update windows and i was use GameDVR_Config tool
but now i try to use this tool again but Also does not work
please help me fast because i use record always for my games for youtube etc...
my system is
Windows 10 Pro 64-bit (10.0, Build 18362) (18362.19h1_release.190318-1202)
Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz (4 CPUs), ~3.2GHz
8192MB RAM
AMD Radeon HD 6670
Display Memory: 4848 MB
thanks
Aug 14, 2019
4
I did not reinstall the program because it is included with the version of Windows and I did not update program in microsoft store too and even after i update did not work also
ConanLock
Commendable
May 22, 2019
1,122
241
1,440
90
You should uninstall your current AMD video drivers, then install the newest available from AMD's website.
If this doesn't work, open Feedback Hub (Windows 10 app, pre installed), and make feedback, including your full system requirements.
Aug 14, 2019
4
thanks bro but i do like what you tell to me but i dont get any solution and microsoft dont do anything to me for Feedback Hub
